Johns Hopkins
thread1452-419159
I'm a quality assurance engineer at a manufacturing facility. My organization has acquired a neighboring chemical plant and I've been consulted about undertaking some possible repair work in a water tank installed there.
The historical reports of this equipment indicate that there has been some nonstandard repair work undertaken on its bottom plate in the recent past.
The details of this work are: an 84 inch long and 12 inch wide welded on patch plate was installed on top of a smaller insert plate within the critical zone.
API-653, Figure 9.13, dictates that the maximum length of the welded on patch plate should not exceed 24 inches along the shell. This nonstandard repair is in clear violation of the code; however, my question is: 'What would the consequence be, if I were to adopt this repair as a permanent one?' It has already been in service for the past 3 years, without the surfacing of any indication.
Is there any specific technical justification to API-653's limitation on the maximum size of welded on patch plate in the critical zone?
J.H
J.H
