Increment size at specific times
For my model, I have implemented a UMAT, and at the end of each converged iteration, a parameter is calculated. The UMAT calculations need this parameter for further calculation.
So the values of my UMAT at time increment i depend on the parameter calculated in increment i-1, i.e. forward calculation. In order to make this more backward, I want adjust the time increments, as such that for example instead of increments at time 0, 1, 2, 3... I have increments at time 0, 0.001, 1, 1.001, 2, 2.001..
Then I can calculate the parameter for example at time 1, and at time 1.001 use this value in the UMAT.
Since I have a UMAT implemented I was thinking of using PNEWDT somehow, setting it to a very small value, but then the increment would stay small.
Is there another way of imposing a certain time increment in ABAQUS?
Note that I cannot calculate the parameter during the UMAT since it depends on the values of all elements (and the UMAT is called for each integration point).
RE: Increment size at specific times
I'm afraid that fixed incrementation (parameter DIRECT) and PNEWDT are the only options that can be used to control time increments. You can, however, force output at given time moments (using Time Points feature).
How does this 'time points' feature works? Does ABAQUS controls the increments such that the exact time points are reached? Or is it purely interpolation based on the converged increments?
By default Abaqus adjusts the increments so that the data is written exatcly at the specified time points.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
