Considerations for creating new manway in Storage tank manufactured in 1958
Hello Reader,
I am looking for criteria/factors to be considered while creating new manway in a storage tank of acid. The tank is designed on API 650 and manufactured in 1958. The old man way is not safe with respect to size of opening and is at the top of tank. I am thinking to create new manway from the shell bottom of tank.
Please guide in this matter.
Thank you!
RE: Considerations for creating new manway in Storage tank manufactured in 1958
Assuming you are not putting a manway in the actual bottom of the tank, use the appropriate sections of section 5.7 for shell manways, review thermal stress relief and toughness of the insert plate / repad / manway components. When in doubt consult with a tank expert or experienced tank contractor.
Quote (Raza Rauf (Mechanical))
The tank is designed on API 650 and manufactured in 1958. The old man way is not safe with respect to size of opening and is at the top of tank. I am thinking to create new manway from the bottom of tank.
I want to understand shell manhole rather then bottom of tank . The tank constructed in 1958 meaning 62 years old.
Did you check the corrosion? what about the hydrogen grooving ?.
Even at moderate conditions ,( moderate ambient temperature, high acid percentage...) the CS tank could be perforated.
If you provide more info. (tank dimensions, material, internal and external corrosion protection..) ,You may get more valuable comments.
If the tank is a welded tank in good condition, it should be no problem.
Many acid tanks have specific gravity higher than 1, so design needs to allow for that, also for any corrosion allowance.
1958 ?....... Hmmmmmm ...???!!!!
Is this an all welded or a rivetted tank ?....... You kinda leave out many important details ...
Acid Storage ?.... What kind ?.... Concentrated Sulfuric Acid or lemonaid ???
Can you post pictures ???
MJCronin
Sr. Process Engineer
It is replacing a portion of the shell which contains the man-way. Follow the PWHT as mentioned in API 650
DHURJATI SEN
Kolkata, India
Apologies for not sharing complete details in post. Please find the missing details below:
Service: Concentrated Nitric Acid
Shell Material: Stainless Steel
Tank Type: Welded (5 layers of plates, bottom 2 layers 5mm thick, middle one 4mm, and top 2 3mm thick)
Dimensions: 8000mm height and 8920mm diameter of tank
Condition of Tank: Not sure from inside as we'll be inspecting tank after 15 years after giving provision of proper manway at shell.
Pictures of the tank will be shared soon.
API-650 didn't include stainless tanks in 1958, I'm pretty sure, and doesn't include 3 mm plate thicknesses, either. So based on that, I would say it is not an API 650 tank.
I assume "layers" is intended to be "courses", that the lower shell is 5mm thick, second course is 5 mm, third course is 4mm, etc.
That said, I assume a new manway could still be added in the shell if desired. You'd need to confirm appropriate materials, weld procedures, and extent of cleaning, etc.
Generally speaking, SS is a good choice for a wide range of nitric acids ... 1958 was along time ago ...
What is the concentration of your acid ?
Above 95% concentration there could be some problems ....
https://www.bssa.org.uk/topics.php?article=31
https://www.rolledalloys.com/technical-resources/e...
The new "all stainless manway" will be massively expensive and may not be a good investment on a 60 year old tank.
Give some thought to replacement of the entire tank ..... You got 60 years use out of it... Pretty damn good !!!
I would, as a minimum, get a few quotes for a brand-new replacement tank and compare it with the cost of a new manway alone...
Let us know what your final soultion is....
MJCronin
MJCronin,concentration is below 95%. Moreover,the party will manufacture manway by its own and new tank is not possible for them in current situation. However, the thickness of tank is satisfactory in comparison to design.
I need guidelines regarding the possibility of new manyway provision in shell and if yes then how to design new manway.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - Strategies to Secure Connected Cars with Firewalls
White-hat hackers have demonstrated gaining remote access to dashboard functions and transmissions of connected vehicles. That makes a firewall a vital component of a multilayered approach to vehicle security as well as overall vehicle safety and reliability. Learn strategies to secure with firewalls. Download Now
White Paper - Model Based Engineering for Wire Harness Manufacturing
As complexity rises, current harness manufacturing methods are struggling to keep pace due to manual data exchanges and the inability to capture tribal knowledge. A model-based wire harness manufacturing engineering flow automates data exchange and captures tribal knowledge through design rules to help harness manufacturers improve harness quality and boost efficiency. Download Now
White Paper - What is Generative Design and Why Do You Need It?
Engineers are being asked to produce more sophisticated designs under a perfect storm of complexity, cost, and change management pressures. Generative design empowers automotive design teams to navigate this storm by employing automation, data re-use and synchronization, and framing design in the context of a full vehicle platform. Download Now
eBook - Simulation-Driven Design with SOLIDWORKS
Simulation-driven design can reduce the time and cost of product development. In this engineering.com eBook, we’ll explore how SOLIDWORKS users can access simulation-driven design through the SOLIDWORKS Simulation suite of analysis tools. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
