Weld Deposit Hardess Testing Exemption - NACE SP0472
Dear experts,
I just read the NACE SP0472 - Para.2.2.3. And I am wondering that how to specify the chemical compositon in weld deposit. Then I do not need to do hardness testing for the weld deposit hardness testing. Can you please help me out. Thanks all.
RE: Weld Deposit Hardess Testing Exemption - NACE SP0472
DHURJATI SEN
Kolkata, India
Hardness testing is cheap, quick and easy. Why not do the test?
The chemistry restriction is not on the weld deposit, just the filler metal. So on your purchase order for the filler metal you add that restriction, the supplier will probably add a bit to the price or maybe not depending on how much you purchase. When you get the filler you just need to review the cert before releasing it into the cage. We had no real complaint when we added the restriction to our ER70S-6.
Bob
