Designer2020
Industrial
Hello All,
I'm looking to obtain internal spline data to match a certain external spec I've been given. Currently here are my know values;
JIS D 2001
260 Nominal
33 Teeth
7.5 Module
H9 / f10
Coefficient of Profile Shifting = +0.633
Pressure Angle = 20°
Basic Pitch Circle Diameter = 247.5
Class = b
Pin Diameter = 13.5
Measurement over pins = 274.717 / 274.564
Base Tangent Length @ 5 Teeth = 106.345 / 106.262
Major Shaft Diameter = 258.5
Minor Hole Diameter = 245
The internal values I'm after are;
Base Circle Diameter
Circular Thickness
Dimension between pins (13.5)
Any help would be greatly appreciated!! I've been trying to calculate these for awhile but the cant seem to make it match up.
JIS D 2001
260 Nominal
33 Teeth
7.5 Module
H9 / f10
Class = b
Pin Diameter = 13.5
Circular Thickness
