How to adjust the field menu in Msc.patran correct to read a *.csv file of Ansys.Fluent Resualts.
rasmir
NL
Hi.
Dear members,
Can anyone help me.?
I've analyzed the 3D model of a blade in Fluent and obtained the fluid pressure and temperature field.
Then I meshed the blade with three-dimensional Tetr4 elements in Patarn.
The layout of meshind grids in the two analytical programs(CFX.ANSYS AND MSC.PATARN) is not similar, but the geometries of both are quite similar.I've got an output file for Msc.patran in export menu of CFX.ANSYS in *.CSV format.I want to read that file in the "field" section in Msc.patarn.But the Patarn get error message in reading of CSV file.
Question:
First, can present the results of the analysis in two different types of meshing(FEM meshing versus Fluent meshing with different number of grid nodes,?
Second, how to set the input parameters(Correct number of text file columns including coordinates of points in three dimensions and pressure value) for reading the file in MSC.PATARN(Field-Table input-(Import/Export file.)-*.CSV File.
The file contains four columns (three columns are the coordinates of points and the fourth column is the pressure value).
The number of rows in a file is six thousand rows.
