Contact US
A53 Gr. B pipe hardness
I’m my plant we have a A53 GR. B pipe that was designed for max temp of 750F as per B31.3
However this pipe was exposed to 950F for almost 10 hours
The pipe didn’t fail or anything but we are concerned that the hardness gone above the limits
Is there max hardness allowed for this pipe that we shouldn’t go above?
RE: A53 Gr. B pipe hardness
Hardness will not be increased.
Weldstan, thanks for your reply can you direct me to a reference ?
I looked at the ASTM standard specification for A53 but there was no mention of hardness
So I’m not sure where can I find more information
The temperature will have to exceed the lower critical followed by rapid cooling to have a potential for increased harness. Your temp is well below the lower critical temperature and the time at temp will actually lower the at room temperature hardness.
The ASM Metals Handbooks amongst other texts provide info in this regard. I have also had experience hardness testing of low carbon steel piping experiencing similar upsets.
so just to clarify it would be fair to say that any cooling rate from temperatures below A1 results in the same
microstructure and hardness?
Yes, but not the same residual stresses.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
