Lateral Building Stability under Wind Loads
Hi There,
When designing a whole building for lateral stability against wind loads, do you consider the height of the building under wind loading as the full height or full height minus half of the first story?
Thanks.
RE: Lateral Building Stability under Wind Loads
Full height, but distribute the loading according to the tributary area of the framing/diaphragms. So in a steel framed building with light gauge studs, the lower half of the first floor would react into the slab or foundation wall, depending on the detailing. If the first floor is a slab on grade, that load generally isn't resisted by the MWFRS. If you have a basement, crawl, or if the structure is elevated, then the first floor would likely need to be a diaphragm and would distribute into the MWFRS. In a structure with girts rather than studs, like a PEMB, all of the load goes to the columns/bents and has to be resisted by the MWFRS.
So in short...it depends.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
