Ferrite Number for CF8M
Hello We have a client specification that require Ferrite Number between 3 to 11 for CF8M valve component. Is it possible to achieve this FN for cast ASS like CF8M ? I have typically seen anything between 10-20 FN for the cast alloys as manufacturer try to get high YS and TS with higher ferrite. If we are not using CF8M at high temp or welding it, can 20 FN detrimental for corrosion properties ?
Thank you.
Thank you.
RE: Ferrite Number for CF8M
As far as the corrosion properties, that is out of my area.
Bob
I haven't made or spec'ed this material, but if I were I would certainly aim for a lower ferrite range closer to the one you quoted (although foundries might balk at aiming for something as low as 3FN). Ferrite enhances castability but it also adds strength. In some environments (e.g. urea) this comes at the cost of corrosion resistance.
I believe the Steel Founders Society (SFSA) has a publication on cast stainless steels.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
I used to use a lot of cast SS parts, but most were solution annealed and they had to be less than 0.5 FN (measured). The as-cast parts were speced as 2-8 FN. The guys that we dealt with didn't flinch at this.
The biggest help of FN in castings is to help resist solidification cracking.
P.E. Metallurgy
