Drawn section cut missing diagram?
emosaka
3
Hi all,
I've been modelling a open-footed culvert on SAP2000 and am now doing section cuts via the "draw section cut" option. The top of the slab worked fine but when I try to section cut the wall the bending moment diagram is not given. See attached, this is an image of the top slab section cut with bending moment diagram. When I do a section cut of the wall though only the values are shown (no diagram).
Any suggestions? Is this a limitation of drawing section cuts?
Thanks! Stay healthy.
 https://files.engineering.com/getfile.aspx?folder=bde1851c-8a06-4c0b-b83a-213b129010a9&file=BMD.PNG
