Pilot seat/cockpit dimensions.
Anyone have some good cockpit dims they are willing to share?
Maybe a copy of MS33574 that has the notes?
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Pilot seat/cockpit dimensions.
Assist & Every spec have the MS33574 'notes' section chopped-in-half. DANG. I submitted a request to ASSIST to re-scan the spec due to this problem.
See attached [my old copy].
https://files.engineering.com/getfile.aspx?folder=...
NOTE. There are [4] standard cockpit dimensions, MS33573-thru-76, thus...
MS33573 [CX] DIMENSIONS, CLEARANCE, COCKPIT FIXED WING AIRCRAFT
MS33574 [CX] DIMENSIONS, BASIC, COCKPIT, STICK-CONTROLLED, FIXED WING AIRCRAFT
MS33575 [CX] DIMENSIONS, BASIC, COCKPIT, HELICOPTER [MIL-STD-1333]
MS33576 [CX] DIMENSIONS, BASIC, COCKPIT, WHEEL CONTROLLED, FIXED WING AIRCRAFT
There are also other documents with relevant cockpit dimensions for MIL aircraft that I am familiar with.
Regards, Wil Taylor
o Trust - But Verify!
2 seat tandem stick controlled fixed wing. Trying to be as small as possible and still comfortable.
MIL-STD-850 Aircrew Vision
MIL-STD-1333 Aircraft station geometry
MIL-STD-1776 AIRCREW STATION AND PASSENGER ACCOMMODATIONS (S/S BY JSSG-2010) {locked in ASSIST}
MIL-STD-1472 Human Engineering
DOD-HDBK-743 Anthropometry of US Military Personnel
www.sparweb.ca
Be cautious... especially if NOT MIL... the requirement for tandem MIL cockpits requires the GIB be elevated significantly, so they could see-forward over the GIF... resulting in a huge cross-section height... many complications.
BTW... several MIL Acft cockpit arrangements are also [somewhere] in the AFSC Design Handbooks [DHs].
NOTE.
In 1980s I [me] designed a single-seat [opt 2-seat] light attack jet... but did not fully adopt the MIL cockpit depth and visibility requirements/constraints... since that would have boosted the cross-section height way-too-much for a compact/LW attack jet. In today's deign world, the T-38 arrangement is completely unacceptable... as evidenced by the cockpit arrangement for the 'MIL-spec' T-7A Red Hawk.
The back seat 'space' was occupied by (a) light gun system... firing below belly, on centerline W/ ammo canister in the cockpit isolated from the pilot; or (b) aft cockpit for an instructor/observer [GIF/GIB in light-weight ejection seats]. The aft cockpit was a pain to get into W/O a side-opening canopy... and I was forced to go-to thru-canopy ejection. Aft cockpit area was very close to the Acft CG so that helped W/ W&B. Arrangement was very tight/compact.
Regards, Wil Taylor
