The problem with this is the "ride through daily peaks and troughs" part. I know of no reactor design that is particularly suited to this. In fact it is far from ideal for reactors to not operate at 100% full power. It can be done, but numerous compromises are made. It is hard enough to run a safety case at 100% full power so there are no safety case for any lower power state. My professors always said it wasn't a great idea to operate below full power. If I had to pick a design for variable power output, it would be a molten salt reactor. There could be various ways in order to vary reactor power in such a reactor quickly. Most importantly, xenon could be controlled quickly. The problem with molten salt is that it is so corrosive, we don't have the materials to build a reactor. The other part is the continuous online chemistry control that is demanded. It would be a lot of work to manage the chemistry and might end up with people being exposed to large amounts of radiation. Lots of problems to be dealt with.
