Surface to surface radiaiton
wasifsafdar
Materials
Mar 13, 2020
1
Hi
I am working on ANSYS 16 Mechaincal thermal analysis. I want to model a surface to surface radation between the two surfaces. The problem is that there is a body in between the two surfaces therefore, I want to enforce ANSYS to see the two surfaces with a few factor of 1 without also giving the ambient temperature setting. If I set the enclosure to perfect, then I get ann error that the enclosure is not perfect, which is true because it is not. Is there a way where I could enforece the view factor to 1 between the surfaces?
