rubber underlay
pruthvi99
Industrial
IN
I am trying to make rubber underlay, it has silver foil on one side and felt on the other, the middle part is rubber sheet, it turns to rubber crumbs if we remove it, we are not able to understand if it is rubber or plastic as after burning it becomes hard and turns into ashes, these type of sheets are made in china only and we need to understand how are they made, so if someone has some knowledge about it please share it, these sheets are used in flooring.
It sounds like this sort of material: and the not so helpful product page
Yes - made in china.
I would not be surprised if it is a rubber that is drawn between felt and the aluminum foil to some thickness and then vulcanized or otherwise cured.
However, I would not be surprised if the material is something that isn't rubber either.
