Seismic Design of Steel building in Nashville, TN
Hello everyone.
I am working on a new steel framed building in Nashville, TN, which utilizes K-braced frames. Most of my projects have been in the East Coast where seismic loads are typically not a concern, hence, we use "Steel Systems not specifically detailed for Seismic Resistance, except Cantilever Column Systems", which has an "R" of 3 - per table 12.2-1 of ASCE 7-10.
If anyone practices in Nashville, TN area, what Building Frame System do you typically use for a steel building?
I understand AISC 341 provisions will come into play if R>3 is utilized.
Thank you.
Thank you.
RE: Seismic Design of Steel building in Nashville, TN
Robert Hale, PE
