AISI 316 yield strength
Dear All,
Is it possible to increase yield strength up to 60K by heat treatment of AISI316 material?
RE: AISI 316 yield strength
The strain hardening will make it stronger, and a little less ductile.
This material will also have a lower service temp as high temps will result in stress relief.
Why do you need the strength?
Why do you need 316?
What about Nitronic 50, or a duplex SS (LDX2101)?
I will add, the material strengths are defined in the material specification, not by the alloy name.
What product form are you working with?
Do you know which ASTM specs cover that form?
P.E. Metallurgy
