2 air compressors in parallel
hi There
we have a scenario to expand the current compressed air delivery ( flow)
what is the practical implications of running 2 rotary screw compressors in parallel?
RE: 2 air compressors in parallel
Put a check valve on each one of them so it is possible to run them one at the time if needed. And/Or a manual shut off valve.
Make sure your piping system can handle the extra flow.
you may need a flow regulator at the end point also.
check your piping rating.
R.Efendy
Two (equal) PD compressors in parallel will attempt to give you twice the air flow. HoWe've of your air system isn't uprated then it could require up to 4 times the pressure.
This may be higher than the compressor rating and lead to increased recycle.
Also you will have twice the heat load so your coolers may need uprating.
Is not as easy as it looks. ...
Thank You
air reticulation will be expanded accordingly
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - How ESI is Helping Move New Medical Device Product to Market Quicker & More Cost Effic
Early Supplier Involvement has long been a strategy employed by manufacturers to produce innovative products. Now, it almost seems like a necessity. Because decisions made in the design phase can positively affect product quality and costs, this can help add value to OEM bottom lines. This white paper will discuss many facets of ESI, including why it’s so valuable today, what challenges limit the benefits of ESI, how cost is impacted, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
