DTI Washer
DTI Washer
DTI Washer
Good Morning:
The same bolt is tensioned with a torque meter and gives a much greater value than the one obtained by applying a DTI washer. why?
Bolt: A325
Diameter: 7/8 "
Torque value: 890 lb-ft
JATE
RE: DTI Washer
Because of surface conditions, a calibrated torque meter does not provide consistent results. The Canadian steel code does not recommend use of this. DTI washers or turn of nut gives a much better indication of the torque provided.
Dik
RE: DTI Washer
What happens if the bolts break before the DTI washer of the indication;
RE: DTI Washer
A DTI is a direct tension indicating washer. Torque is only sort of an indication of tension. You could probably benefit from the videos and information at this website: https://www.appliedbolting.com/video.php
RE: DTI Washer
If the bolt breaks before reaching the required tension as indicated by the washer then the bolt is either the wrong choice or a defective bolt or the wrong DTI washer. The defect might be from manufacture or from mishandling/corrosion.
RE: DTI Washer
Quote (JATE (Mechanical))
If the difference is 10% , it is O.K...For preloading of bolt with torque control method, the torque is applied in two steps. The first step is to apply a torque of up to 75% of the required torque value to all the bolts and second step is to apply additional torque so applied torque is 110% of the nominal torque value. when the tightening wrench is removed , torsional relaxation will occur this is the extra 10% of preload.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Manufacturing the Cars of Tomorrow
In this ebook, we'll explore how additive manufacturing is going to transform the way cars are made. This includes commentary from thought leaders such as Ford's CTO, Ken Washington, Customer case studies of ways 3D printing is being used today, and a variety of part examples where 3D printing is already impacting how automobiles are made. Download Now
White Paper - Smart Manufacturing for Semiconductor
New technologies and approaches present great opportunities for semiconductor manufacturers to achieve high levels of innovation, yield and improvement. This white paper explores some of these cutting-edge technologies and how they can be applied effectively in the semiconductor industry. Read about how Smart Manufacturing is transforming the semiconductor industry. Download Now
White Paper - Analysis and Simulation in Aircraft Structure Certification
Organizations using simulation and analysis tools effectively see the benefits in their ability to achieve certification faster and with drastically less total cost than those who do not maximize these tools. Read this White Paper to learn about how digital tools such as analysis and simulation help in aircraft structure certification. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
