Hi everyone,
We have just received an enquiry that is reversed engineering of a control valve cage with thousands of holes. Our manufacturing manager has calculated the required time for machining all these holes (OD=1.5 mm) about 1500 hour with manual milling machine.
My question is: Is there any faster manufacturing method for machining all these holes??
Thank you in advanced.
