Hi everyone,
I need to carry an ultimate load of 31 kN on 2M20 - 8.8 bolts. the bolts are vertically inline and the load is eccentric to the centre line by 400 mm.
this results in 31 kN shear force vertical and mt=13 kN.m
the question is if I hang the load on the two bolts will the shear force distribute equally between the two bolts considering there is 800 mm distance between the two bolts?
