Grout Filling Abandoned 4" dia Waterline
sportsnut44
I am abandoning about a half mile of existing 4" diameter steel waterline, and the pipe needs to be filled with some sort of non-shrink grout or similar. Since the pipe is only 4" in diameter, I have a few questions:
• What type of material should be specified for the flowable fill, i.e. cellular concrete, polymer-modified grout,...?? Or will a standard cement slurry mixture work that is typically used for larger pipe abandoning?
• How many feet of pipe can be filled at a time with a single point of entry and vent at the other end? Should it be limited to say 500 ft at a time, less, more,...?
• What is the approximately cost of this?
• Line has shallow cover with significant surface loading. Is this a concern for certain products used to fill the pipe?
Thank you and I look forward to hearing back as soon as possible.
4 inch? Just fill it with water and abandon
Or bentonite
If someone really really want to spend money for no benefit then foamed concrete is pretty good.
at 4 inch you're probably pressure limited but how far? - need to ask some vendors. My guess would be 400m
If it's that shallow can't you dig it / rip it out of the ground?
I concur with LittleInch, filling a pipe with traditional grout - is a bad idea. I am guessing that the DOT is wanting it filled, as they tend to make obscure requirements such as this. Point them to a story in Atlanta a few years ago where the road buckled because they required a pipe to be filled with grout. If they do make you do this, you will need a very flowable slurry type mix though.
