Contact US
design stress limit for brittle material
I am working on a design for a die cast aluminum part, alloy EN AC-Al Si9Cu3(Fe) in as-cast condition. I am wondering what stress level to use as a limit for fatigue failure. I have read that because the material is so brittle that it is acceptable to just use the ultimate tensile strength of the material (240MPa) because there is no clearly discernible transition from elastic to plastic deformation. However, the yield strength listed in the material spec is 140Mpa. Elongation at break is 1%. So what's the preferred approach? The lifetime load cycles in my application are low, only a couple million near peak load.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
