How we should understand the table in point S.3.3.1 about minimum nominal thickness.
In CS tank for nozzles from 8" to 24" we read pipe thickness 12.7mm using the table 5.6a, for SS tank S.3.3.1 gives only information that nozzles above 4" have to be minimum thickness 6mm. The difference is noticeable.
And the question is which value we should take in case of SS tank, higher? Or just simply we take values from S Annex.
