Contact US
SS Bolts for Incoloy 825 Valve
Need expert metallurgy advice on galvanic corrosion for using stainless bolts on ASTM B564 N088825 (Incoloy 825) valve body-bonnet bolting.
Project specification allows to use austenitic stainless bolting AISI Type 316 (per A193). However, need clarity with respect to galvanic corrosion.
pnrngv
RE: SS Bolts for Incoloy 825 Valve
Why are you using 825 in this system?
The 316 will be less corrosion resistant and weaker.
Is 316 what the valve manufacturer recommends?
Make sure that you use the correct specification, there are different strength levels of 316 hardware.
And use a good anti-gall.
P.E. Metallurgy
Is the valve installed in a corrosive environment or is it handling a corrosive fluid? In most cases the bolts are isolated from the fluid by gaskets so unless you have a leak, galvanic corrosion of the bolts shouldn't be a problem.
825 per B564 is fully annealed, 316 per A193 be slightly cold worked, so strength levels are pretty much comparable. 316 is obvious less corrosion resistant. That said, when both alloy are passivated, their potentials are pretty close (with 825 a little more noble), galvanic corrosion is not a big concern.
Hi EdStainless
It is the project specification requirement. This is 3/4" gate valve provided as a Drain valve for 8" Ball Valve.
Specification calls for Inconel (Same as Trim of Ball Valve).
No. In Project specification, it is specified to provide AISI 316 bolting.
Hi Tuboateng
It is Onshore upstream Gas field. Inconel Gasket are provided for the valve.
825 is an Incoloy, an iron based alloy. There are about 25 of these grades. And there are about as many Inconels which are Ni based alloys.
If the requirement is for Inconel bolting then you need to look for alloys like 625.
I am not worried about galvanic issues but rather crevice corrosion and chloride stress corrosion cracking of the 316 are what will limit its life.
P.E. Metallurgy
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
