Contact US
Metal Spinning Deformation
This shell made by metal spinning keeps deforming and I do not know why. There is no problem in the tooling. It is an issue with the material. I do not which mechanical property is the root cause. % elongation 38.4%, maximum tensile strength 426 MPa and yield strength 266.9 MPa. All three properties concur with the standard values. Any help in this matter will be highly appreciated.
RE: Metal Spinning Deformation
Is the issue some un-identified "deformation" in the picture, or what looks like cracking at the inner ends of the 2 small crimps at 12:00 o'clock on the small diameter?
is the entire part spun from plate or sheet metal ?
Based on virtually no information I think I'd warm up the small diameter to anneal it before forming the crimps.
I thought deformation was the purpose of metal-spinning...
Mike
I'm certainly not an expert in spinning but to me it appear to be a problem with the spinning technique. The material buckled because too much deformation was attempted in one pass. Another issue could be lubrication. Poor lubrication during forming could promote buckling. The poor surface finish tends to point to this. Spinning is primarily a stretching process. These are compression buckles. You must stretch the material lengthwise while avoiding excessive compression radially (or circumferentially).
If you don't know what is causing the issue, how do you know that it is a material issue? Have you compared material certifications for lots of material that did not have the problem to lots that showed the problem?
Sorry guys if I wasn't too elaborative. The crimps you see in the picture are the abnormal deformation. I know there is something wrong with this material because I have changed machines and this same problem arises and when I change the material this problem goes away. There is no issue with the spinning technique and lubrication.
Four numerical place values on a yield strength is suspicious. Try checking the material hardness.
Short answer - dunno, I let our spinning shop worry about the details, I just know that spinning is more of a black art than a science. But before blaming the material, I'd be sure to check:
Is this manual spinning? Same operator?
If machine (NC) spinning, same tool and buck (form), same rpm profile, checked the lubricant delivery? Do you see any signs of the material slipping/galling on the buck or at the clamp interface?
For the material I wouild check yield strength and elongation, initial material thickness, and rolling/forming grain direction of the two materials. Also confirm condition (as rolled, annealed, pickled...etc.)
What is the material you are working with? What do you mean by "change material".
By material change I mean I checked the mechanical properties of the material and the young's modulus varies from 15000 MPa to 22000 MPa. All else remains same. I haven't checked the strain hardening of the material. I just want to confirm whether my hunch is right and whether I should contact my supplier to replace the material.
" the young's modulus varies from 15000 MPa to 22000 MPa"
The 15 GPa modulus is a fictitious number, no metal alloy I've heard of has a normal value near that. 22 GPa is near typical for a stainless steel. How were the moduli determined?
It looks like you are doing a diameter reduction of a tube? That's a pretty tricky process, and local buckling due to high tangential forces (friction) is an expected failure mode. Try doing in-process anneals at finer reduction ratios, changing lubricant, using a roller rather than a spoon-type tool, or using multiple tools to reduce/distribute the tangential forces.
What is the metal alloy.
You've not yet explained this part. What is the material change? How do you know you've change the material if you can't tell them apart?
If you look at the YouTube videos for spin forming, you'll see people using additional tools to constrain the free end, and something like that might prevent the buckling. What seems odd is the sharpness of the buckle, so possibly your tool is too small?
TTFN (ta ta for now)
The sharpness of the buckle is as should be expected. It is the lowest energy mode of buckling failure. Once the buckle starts, all of the elastic energy of the compressive stresses in the circumference will be released at the one point. There are other constraints like the fact that the compressive stresses are due to being attached to adjacent material that has tensile stresses and the metal has a shear strength. So a buckle can only relieve stress over a limited distance. This is why there are several buckles.
"I just want to confirm whether my hunch is right and whether I should contact my supplier to replace the material. "
What part of your purchase order/specifications did the material supplier violate that they should replace it? Or did you just mean buy new material?
The tests were conducted using a universal testing machine. Two rollers placed either side of the shell reduce the diameter. The materials come in different pallets. The first pallets material gets formed correctly, except for the other three.
1) Yield Strength= 244 MPa
Ultimate tensile strength= 408 MPa
Elongation= 39%
Young's modulus= 15.9 GPa
2) Yield Strength= 263.5 MPa
Ultimate tensile strength= 422.8 MPa
Elongation= 37%
Young's modulus= 18.5 GPa
3) Yield Strength= 263 MPa
Ultimate tensile strength= 421 MPa
Elongation= 37%
4) Yield Strength= 267 MPa
Ultimate tensile strength= 426 MPa
Elongation= 38.4%
Young's modulus= 22.2 GPa
All four materials are in within the standard range except there is no standard for young's modulus. The first material gets formed correctly only.
If the material meets your specification then its on you. You cannot expect the supplier to be responsible for criteria that is not in the purchase order.
Do the properties match the material test reports from your supplier? If so have you reviewed past certifications to see if you have had material with similar mechanical properties? If you have had material with similar properties that did not show this type of failure then you need to start asking yourself what is different about this batch or what has changed in your process. If not then you need more data points for failure before changing your material specifications.
First I would look in my inventory to see what material I have on hand that I could test to ensure that I can turn the problem on and off. Barring that I would work with your supplier to see if they can provide you with some sample materials of different strengths to ensure that you have indeed spotted the problems.
Then comes the negotiations with your supplier, as you will need to tighten up your material standards. Anytime you tighten up your standards, your supplier will want to increase the cost and justifiably so.
Ok, something is still not right with the tensile modulus numbers you are quoting. 15.9 GPa to 22 GPa is equivalent to roughly 2.3 e6 to 3.2 e6 psi, i.e. about a factor of 10 below typical steels.
Assuming your numbers are off by a factor of 10, something is still not right with the first, "good" material modulus, as again, no alloy (not steel, not titanium, not brass or bronze) has a modulus anywhere near that value even when it is multiplied by 10. From the photo, your material looks to be stainless steel, but you've never explicity stated the alloy so we are just guessing.
0. What material (steel, stainless steel, alloy steel?), what alloy (304?), what condition (as rolled, annealed?)
1. Who did the material testing, and in what form was the alloy when the test was done?
2. Looks like you are starting from a tube - was material testing done on the as-received tube?
3. What tolerance variations exist in the as-received product? Does the "good" material run a bit thicker or thinner than the others?
4. Are you doing any in-process anneals, and if not why not?
What strain rate did you use for tensile testing? What did the samples look like?
What do the curves look like?
I agree, you modulus vales are wrong. And the modulus does not change for a given alloy. If you are reporting different values it is an artifact of how you are interpreting the tensile curves. There may be some clues in those curve shapes.
What specification is the material purchased to?
You need to add a lot of info before we can help you figure out where to look.
P.E. Metallurgy
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
