Contact US
Imbalance Unbalanced?
I am never sure of the proper usage and choice between these words.
Bill
"Why not the best?"
Jimmy Carter
RE: Imbalance Unbalanced?
I thought it was an unbalanced imbalance... winky smile
Thanks David. That sort of evens things up. grin
Bill
"Why not the best?"
Jimmy Carter
One's the noun; the other an adjective.
Unbalanced phases have got an imbalance.
A.
Unbalanced phrases that are unbalanced produce an imbalance... adjective, adverb, and noun..
Mike McCann, PE, SE (WA, HI)
Mike, I'm not really getting much sense of an adverb there.
A.
"unbalanced" is modifying the verb "are", hence it is functioning as an adverb.
Setting aside the adverb which confuses me 3eyes ....
...did we learn above to use imbalance if it's a noun and unbalanced if it's an adjective?
I dunno.
unbalance can be a noun. https://www.lexico.com/en/definition/unbalance
imbalanced can be an adjective https://www.merriam-webster.com/dictionary/imbalan...
So far it seems like a coin flip.flip
Standards like ISO 1940 for rotating machinery mechanical balancing to reduce vibration use the term unbalance as a noun.
I'm not sure about electrical standards like IEEE 100 that might refer to unbalance / imbalance of voltage, current, winding resistance etc. Until I hear otherwise I'll just stick with the coin toss for electrical unbalances/imbalances (someone would probably disagree no matter which one I choose).
(2B)+(2B)' ?
Per Pete's signature, I suggest (balance)'.
In your sentence, both uses of "unbalanced" are adjectives modifying "phrases".
As far as "conventional" (i.e. proper!) English is concerned:
"imbalance" is a noun
"unbalance" is a verb
"unbalanced" is an adjective
Other word forms may be encountered in "jargon" (e.g. using "unbalance" as a noun) - but I would always prefer the "conventional" usage.
http://julianh72.blogspot.com
Are is a verb, and any verb can only be modified by another verb or an adverb.
Dictionary (Oxford)
are1
/är,ər/
verb
second person singular present and first, second, third person plural present of be.
are2
/er,är/
noun
historical
noun: are; plural noun: ares
a metric unit of measure, equal to 100 square meters (about 119.6 square yards).
Origin
late 18th century: from French, from Latin area (see area).
I suggest testing the adverb theory using something that undeniably is an adverb in the same sort of way to see how it turns out.
Snails are slowly
In my head, when you say something is unbalanced, "unbalanced" is working as an adjective which qualifies the implied (but silent) Complement of the verb, rather than qualifying the verb. It tells you what the thing is being, not how it's doing it.
A
Or conversely, create the shortest grammatically-correct sentence containing the verb "are", as an aid to parsing the structure; e.g.
Snails are molluscs.
"Molluscs" is NOT an adverb - and neither is "unbalanced".
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
