how can i find the wheel angle ( not the steering angle ) in PostProcessing in Adams/Car
hi everyone
I guess the subject asks the question by itself .
I can't find the wheel angle that is the result of the steering angle in Postprocessing .
I have looked everywhere in Postprocessing Results and I couldn't find it .
I have looked for a toe request but it gave the following result that I know is not correct because it should give a constant like steering angle:
appreciate it if anyone could help
RE: how can i find the wheel angle ( not the steering angle ) in PostProcessing in Adams/Car
Cheers
Greg Locock
I see absolutely no such request in here ? not in the requests nor in the components …
could you please mention the branch that you have found Toe castor camber in ?
I have looked everywhere ...
REQ/1080,FUNCTION=USER(1101,0,10405,10421,0,10505,10523,5199,0)\
, TITLE= Toe_Caster_Camber_Front
, COMMENT=TOE CASTER CAMBER (FRONT)
, CNAMES = ""
, "LF_Toe_Angle"
, "LF_Caster_Angle"
, "LF_Camber_Angle"
, "RF_Toe_Angle"
, "RF_Caster_Angle"
, "RF_Camber_Angle"
,CLABELS="","(deg)","(deg)","(deg)","","(deg)","(deg)","(deg)"
, RESULTS_NAME = Toe_Caster_Camber_Front
Cheers
Greg Locock
maybe step by step …
I don't know where I should add custom request code so I could do the rest of the instructions that you just added …
appreciate it if you help out more
Cheers
Greg Locock
