elements to increase the impact test
For a carbon steel, how elements /structure is the best to obtein a good impact test result at -20 / -40ºC.
We melt a steel with target values aroung C=0.20 Mn=1.50 Si<0.30 V=0.12 after normalizing (ferrite and perlite with a grain size around 9) but the impact test at -20ºC is not more than 50J.
How I can increase those values?
Thank you
Thank you
RE: elements to increase the impact test
For carbon steel, normalizing, with sulphur below 0.010% should get you good impacts at -40°C. The steelmaking method also comes into it.
Avoid spicy elements like V and Nb.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
yes you are right..but it is a cliente requirement S=0.020-0.030.. i know S is not good for impact test.. that's why i have to do something to minized the Sulfur. V>0.12 is also a requiremet.. i can not do nothing with it.
The standards always are wide in composition
I have read that the S bad influence can be minimized with Mn.
Has ASTM some standars for carbon steel like have the European ones? For mechanical use? with Yield >50ksi? I know the A106, A333, A105, A519.. but no one have a steel like S355J2H (EN 10210-1) or like 20MnV6 (S460NH)..etc.
How is it being deoxidized?
How is the steel being formed?
You stated that the heat treatment is normalized. Is that per the clients specification?
What mechanical properties are you trying to achieve? Tensile/Yield and impact.
What form is your test coupon?
What is your nitrogen and oxygen content?
Bob
How is it being deoxidized? Al-Si fully killed
You stated that the heat treatment is normalized. Is that per the clients specification? yes
What mechanical properties are you trying to achieve? Tensile/Yield and impact. Yield >450 Mpa Tensile >600Mpa, elsong >17% impact test -20ºC, 65 j average
What form is your test coupon?longitudinal roud 14mm OD (according to EN /DIN) - long. impact test Charpy 10x10
What is your nitrogen and oxygen content? N<0.012 O<0.005
Quality S460NH acc to EN 10216-3
In addition to the comments provided, You did add Al for fine grain melting? While V will provide fine grain melting, Al should be added as well. Yes Al >0.020 (according to the norm)
THANK YOU
Bob
Once again, what is the problem you are trying to solve?
Not surprised that impact test values are low when you normalize a V- Nb-bearing steel.
