Weld joint P11 to P91
Our contractor is going to weld P11(P4) to P91(P15E), they have PQR but i have still doubt for PWHT,and looking for expert advise.
PWHT is required after welding,and they used 750c holding Temp.however recomended temp from ASMEB31.1 650 to 705 for P11 and 735 to 775 for P91.
my question if they use 750 deg.C for P11//P91 weldment,sure they temp beyond the limit of P11 material,So Question is if they go beyond the ASME recomendation what risk involve, what effects on material properties ?//??/remember this piping for Steam (137bar 537 C)
what do you suggest as safe or good engineering practice???
thanks,
thanks,
RE: Weld joint P11 to P91
Choose the filler metal with caution; matching the P-91 base metal could lead to undesirable effects at the interface on the P11 side of the weld.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
can u encompass what maximum changes in microstucture can occur if used 750c PWHT for P11/P91 weldment??
