What should be the connection betwe
What should be the connection between a pvc ball valve and a flexible hose that will go to a sewage pit. Also is better to just hang the hose loose in the pit or connect it to a pipe.
RE: What should be the connection betwe
No way to know what's the better setup as you didn't specify what are the application conditions or any requirements.
The application is sewage water removal. The size of the line is 25 mm
That size and application: neither, use hose clamp for easy removal and cleaning. Other connection depending on environment use/use. What about having the hose outlet end secured and steered by putting the hose end into a (fairly) larger dimension firm pipe fastened to the (side wall? top cover?) of the pit.
Yes, I thought of doing that set in the pit. But that is not the connection used in the old plant.
Is this the connection you mean between the valve and the hose
Yes, but all would be depending on surrounding, technical and practical circumstances. No absolute answer.
If your pipe connection can handle the weight of your pipe full of water then hanging it loose is Ok, but might look bad depending if there is any movement.
If you are pumping in then I would fix it to stop the jet of water from moving the hose around, but depends on your velocities.
Connection? - Up to you - what ever works. Usually imposed by whatever the hose connection is that it comes with. A machanical joint is a lot easier to undo and replace, but not "required" if a clamp is good enough.
A picture would help....
