I am looking at a 1980's ranch on concrete basement foundation with brick veneer. (picture attached)
Preliminary indications are that brick ties were not used.
There is 1" rigid foam between the wall studs and the brick.
Not sure yet if there s plywood sheathing on the walls but I think there is.
No abnormal cracking on the drywall inside.
Not a foundation movement problem.
Here's the issue - The brick is buckling outward at about 2/3 to 3/4 up from the bottom of the wall. Bowing is very slight (1/4" +/-) and horizontal crack is consistent and seems wider at the outside face of brick.
I'm wondering what force would be causing this behavior. Maybe some sort of weathering?
House faces east and east face is least affected.
Looked up under the soffit and it does not appear that there is any roof truss bearing on the brick.
I know this is a red herring but... any thoughts?
