Contact US
Descriptive words for varying L/D values
Hi everyone,
When describing objects that have a length to diameter ratio (tanks, capsules, etc.) I will normally say something is "slender" if L/D >> 1 and "squat" if L/D << 1. Is there a descriptive term for when L/D is around 1? Would "isometric" be a proper engineering use of that word, given its definition in English (as given by Google: "of or having equal dimension")?
RE: Descriptive words for varying L/D values
When and engine bore/stroke ratio is 1:1 it's called square. I've not seen that used in other context.
"Aspect ratio" is the generic term. "Square" makes sense for 1:1, but I'm not sure what I would use for near 1:1.
--Winston S. Churchill
The tank would be "unsure of themself"?? smile
On the cusp
Trans-squat or Trans-slender
I also saw this online somewhere - they use the terms "short", "intermediate" and "long"
So the term intermediate might apply to your question.
squar-ish ? almost square ??
but why give it a name ? the slenderness ratio of the box is 1.1, or the L/D of the box is 1.1, or the box dim'ns L = x, D = y, slenderness = L/D = x/y ??
@rb1957
I don't use the descriptors if I can define the L/D but I was just wondering if there was a commonly used word from other disciplines that I could adopt into my ChemE brain. I find it useful to have these words handy to use when speaking with other disciplines on projects or to more clearly define conceptual writing if I define my own jargon in the document and then I know everyone's speaking the same language when referencing a certain document (that's the hope anyway).
then square or squar-ish should be good enough for conversation. Rectangular is more correct, but less expressive?
I would just say "square" unless it being not perfectly square was consequential in which case I would use "relatively square".
Andrew H.
www.mototribology.com
Thanks everyone, "square" it is!
Getting back to the engine terminology, the the bore is bigger than the stroke it is over square and when the bore is smaller than the stroke it is under square.
"Dumpy"? I've seen that used in the context of short portable cylinders that are still a bit longer than square.
For things a little shorter than square, the word that comes to mind is "Squat" - though I don't think I've actually seen it used in this sort of context.
A.
Low aspect ratio works in many contexts.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
