Welding CS to Cs with ER80S-D2
Ive been tasked with reviewing a boiler repair performed several years ago by a well established vendor.
Replacing several boiler tubes in several different boiler sections. Header/tube material garden variety 10" sch 120 SA 106 B/ 2" 120mw SA 178A. Nothing special about this configuration.
For the tube to header welds, I would have expected to see a GTAW procedure using ER70S-2 and maybe an additional/combination SMAW procedure using 7018
In this case, all the root welding was done with ER80S-D2/7018 Nothing particularly wrong with it...just havent seen it done before.
Why choose the ER80S-D2 over ER70S-2? It would seem the Moly addition would decrease weldability in an allready limited access configuration (and bring weld preheat into the job)
RE: Welding CS to Cs with ER80S-D2
Have a read of SFA-5.28, Annex A, A7.11 for a pretty good description of this electrode.
The devil is in the details; she also wears prada.
ER80S-D2 is perfectly suitable for the task, with no decrease in weldability. You could even safely weld over existing D2 deposits with ER70S-X carbon steel filler.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Al
Best regards - Al
I don't recommend that, I'm just saying it would be technically doable. There are obvious complications for a WPS in mixing classifications and A-numbers.
