PWHT of duplex stainless steels
Hello, all,
I've read around these forums and have come across a seeminlgy consistent opinion that post-weld heat treatment is not a recommended pratice for duplex stainless steels on account of the possible formation of a deleterious phase in the material.
What is making me uneasy about this whole topic is how both ASTM A790 and A928 require welded pipe to be heat treated, unless otherwise explicity ordered.
What am I missing?
Our pipe spec calls for A790 pipe, and a vendor is offering to furnish welded pipe without the heat treatment. Given that the ASTM standards explicitly allow for the purchaser to make a requirement on the necessity of heat treatment, in what situations would it be necessary/recommended?
Thank you.
What am I missing?
Thank you.
RE: PWHT of duplex stainless steels
What I can say about duplex SSs is that post-weld stress relief as it is typically understood (e.g., 1100°F) is forbidden for the reasons you state in the first para.
Duplex SSs, welded or not, come with a service temperature limit of around 600°F.
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
If it is supplied un-HT the documentation shall show that the plate was properly heat treated, and that the finished pipe meets the A923 requirements.
All duplex pipe and tube should be tested to A923 B or C. All, every time.
Are you welding any of this pipe in your system? Have you tried qualifying welds to A923 when they are done on HT-0 material? My hunch is that you can't.
P.E. Metallurgy
@ironic_metallurgist, is that to say that heat treatments performed at a higher temperature than that usually associated with PWHT stress relief are acceptable?
I am still in doubt about this issue:
ASME B31.3 has this to say about requirements for postweld heat treatment of duplex stainless steels: "Postweld heat treatment is neither required nor prohibited, but any heat treatment applied shall be as required in the material specification."
@EdStainless, I've so far understood "postweld heat treatment" to mean any treatment involving heat applied after welding, regardless of duration, intensity, and prescribed cooling process of said treatment. Is it the case that in the industry, in English speaking countries (I'm not from one), that the meaning of the term "PWHT" is usually restricted to a subset of possible heat treatments? In any case, isn't B31.3 defining the PWHT for DSS to be that which is prescribed in the material standard, such as A790 and others? As such, is the full anneal the applicable heat treatment for postwelding? Is my understanding correct?
Also, I've checked that A790 references the requirement that DSS pipe be tested against A923, in the event that heat treatment is omitted, while A928 makes no mention of it; it simply states that such pipe must be appropriately marked, as does A790. What gives?
Coming from a SS background I think of PWHT as being sub-critical, in other words not a full anneal. But I am not sure that that is technically correct.
And for virtually all stainless alloys this can pose serious problems.
That is why you have the statement in B31.3 saying any PWHT must comply with what is required in the material spec. I have seen people building spools in a shop and giving them a full anneal after welding. The other issue with duplex SS is that they are very quench rate sensitive, just getting the temp correct does not finish the job.
P.E. Metallurgy
As to the pipe the vendor is offering to furnish, if it won't be heat treated, it must pass tests per A923, as stated in A790, correct? I'm coming to understand that the PWHT for DSS people here were advising against is not a full anneal, but rather a sub-critical heat treatment. The full anneal is not only recommended, it is mandatory, unless conformance to A923 is proven. This full anneal would also be the only acceptable heat treatment for postwelding of pipe spools -- if heat treatment is called for -- as per B31.3 -- and it is acceptable, as you mentioned having seen happening. Am I following?
On another note, out of curiosity, is there something in the content of A928, or is it something more historical/pertatining to its actual application in the industry, that indicates it to be pipeline-oriented?
Thank you once more for your help.
S31200, S31803, S32550 PWHT 1900 F (min), liquid quench or rapid cool by other means
Mike
https://www.iogp-jip33.org/product/S-563v18-12.pdf
It might also pay to brush up a little more on metallurgy and fabrication practices.
Steve Jones
Corrosion Management Consultant
www.linkedin.com/in/drstevejones
All answers are personal opinions only and are in no way connected with any employer.
Duplex is not for beginners; in fact it is a class of alloys I would rather avoid because of the extreme level of controls and testing necessary for maintaining full corrosion resistance.
SnTMan, A790 establishes very similar minimum temperatures and rapid cooling for the heat treatment of those grades of DSS. I gather that the PWHT mentioned in B31.3 for DSS is in fact the full anneal required by these material specifications.
SJones, thank you for the document, it will be of much use. Do you have any other specific references on metallurgy and fabrication practices that you deem especially helpful? As to striking the vendor off the client's approved vendor list, I have nowhere near as much authority to do so... Though if it must be, I'll require they include PWHT in their technical proposal. If they can't comply, I'll turn down their offer.
On topic, I'd like to clarify some final things:
- ASTM A790 requires a PWHT for welded pipe or assurance that the pipe complies with the testing requirements of A923;
- Subcritical PWHTs for DSS is not recommended. If a PWHT is necessary, the minimum temperature at which it is applied must be greater than around 950 °C, in order to prevent the formation of deleterious intermetallic phases.
With that in mind, is there something fundamentally different between the seam weldment of a DSS pipe and the weldment bonding two lengths of pipe to form a spool? I believe that in the latter case, it is not very frequent that a full anneal PWHT is executed. However, why is it a necessity in the manufacture of pipe itself? A790 requires the weld be fillerless. Is it a matter of filler vs. fillerless? I can't exactly see why this would be so great a discrepancy so as to rule out PWHT. What am I missing?
Search on 'practical guidelines for the fabrication of duplex stainless steel.'
Good welding specifications usually detail requirements for processes, consumables, corrosion testing, etc, etc to a level that accounts for the absence of subsequent heat treatment.
Steve Jones
It is indeed a matter of filler vs. fillerless, which I don't think has been mentioned so far.
Matching filler metal for 22-5 is overalloyed to the tune of 9% Ni, which accounts for the cooling cycle experienced by weld metal and helps it achieve the appropriate ferrite/austenite balance matching the base metal. A solution anneal heat treatment negates this approach and will leave the weld deficient in ferrite. So if annealing is planned you would either used a compositionally matching filler metal (I doubt one is available) or weld autogenously. In terms of maximizing the properties of a duplex SS weld, autogenous + solution annealing is the optimum approach, although it is expensive, impractical and often impossible.
On that note, beware of heat exchanger tube constructed by autogenous, high-speed electric welding that is not subsequently solution annealed. There is lots of this cheap material on the market, but I would never consider it because the weld deposit corrosion resistance is significantly compromised by this manufacturing route.
Yes Springwater, you are on the right track.
The lean duplex grades (20-21%Cr no Mo) are easy to work with and very forgiving, 2205 is not bad in thinner sections, the super duplex grades are difficult even in tubing gauges (<0.100") and heavy sections require great expertise.
Duplex alloys in general are great. They have excellent strength, a useful level of Cl SCC resistance, and they are a very efficient use of alloying elements (pitting resistance vs alloy content).
However they do have a limited temp range (0 - 600F), can be tricky to weld (and still get good pitting resistance), and the processing can change the properties.
One example of this last point is that the anneal temp determines the A:F ratio. With austenitic stainless it just has to be annealed enough, and over annealing doesn't cause harm, while in a duplex annealing at the bottom end of the range vs the top can shift the A:F ratio 15% or more.
P.E. Metallurgy
I'm sorry I didn't get back to this soon enough. Picking up where we left, I'd like to press on a little longer.
The filler having a different composition which obviates heat treatment post-welding makes sense. However, ASTM A928 specifies E2594/ER2594 consumables for welding UNS S32750 (the pipe spec with which I am involved right now). And those consumables have exactly the same composition as UNS S32750 itself! So it is indeed a compositionally matching filler. The consumables listed for other grades of base material are not matching though. Yet A928 makes no distinction between grades and how one should proceed with respect to heat treatment. Recap: A928 has this to say on this topic:
So no reference to ASTM A923, as A790 makes, as we've said before. Yet heat treated is still the standard condition, matching filler or not. Some thoughts and questions:
- UNS S32750 pipe is welded with a matching filler when fabricated into spools. Usually though no heat treatment is specified. Yet heat treated is the standard condition for pipe as per ASTM A928, and the purchaser ought to specifically request that pipe not be heat treated and appropriately marked. Is there something fundamentally different between filler-weldments during pipe manufacture and spool fabrication, given that both employ the same filler, to explain the different approaches to heat treatment?
- A790 specifies fillerless welded pipe. Is there something fundamentally different betweent an autogenous weld and a weld made with a compositionally matching filler? Different temperatures, durations and strains, leading to heat-affected zones with different characteristics, maybe? A790 makes a point to ensure that pipe that hasn't been heat treated comply with ASTM A923, which is a step-up from simply requiring special marking.
Thank you all for your time and attentive input.RE: PWHT of duplex stainless steels
Steve Jones
There is a difference in welded DSS tubulars with and without filler metal - thickness of tubulars and volume of melted material in the joint which will affect austenite/ferrite structure and balance.
On heat treatment, I'm gathering that it would not be recommended for filler-welded pipe/spools on account of it throwing off the A:F balance. But why then is heat treated the standard condition in A928? The standard specifies filler-welded pipe manufactured from plate, and recommends the over-alloyed-with-nickel consumable. Shouldn't that preclude heat treatment, given that the plate from which the pipe is made must comply with A240 and would already have received heat treatment in accordance with A480 (the same heat treatment required in A790)?
Thank you.
1) Welded without filler metal >> solution anneal heat treatment (excepting perhaps lean grades in mild environments)
EXAMPLE: Electric welded tube & pipe must be solution annealed.
2) Welded with filler metal >> enhanced Nickel filler metal + no heat treatment of any kind is permitted
EXAMPLE: Grade 2205 Duplex SS (22Cr/5Ni) is welded with E/ER2209 filler metal (22Cr/9Ni) and is not subsequently heat treated.
I must add that choosing the correct filler metal for ferrite balance is only the first of several challenges in welding DSS successfully. As I said, fabricating DSS is not for beginners.
@ironic_metallurgist, that's the thing... A928 pipe is welded with filler metal, but the standard still calls for heat treatment, unless the purchaser specifically requests that none be carried out. ASTM A815 allows for fittings welded with the addition of filler metal, and indiscriminately requires heat treatment, filler or no filler, necessarily *after* welding:
That doesn't make much sense from what I've learned from this thread... Any thoughts?
Welding and HT duplex isn't that difficult, but it is a lot harder than working with 300 series material. In many ways it is more like working with high strength steels.
You have to watch heat input, interpass temp, cooling rate, gases for weld and purge, and a few other things all at once.
P.E. Metallurgy
I consider ASTM system to be the gold standard for technical standards (sorry). However, they can be painfully uninformative in the heat treatment department (one example is A352, which I am currently dealing with, says basically nothing). That said, codes and standards can give useful guidance, but they are not meant to be prescriptive in all aspects, and they certainly are not design guides. Ditto for corrosion considerations.
If there are exceptions to my previous summary (and material producers will find ways to make cost-cutting exceptions), they must be addressed on a case-by-case basis and validated by relevant testing. The goal is to achieve the full potential corrosion resistance of the CRA grade in the finished product, over every square mm.
A thorough purchase specification for duplex SS fabrication will include a large number of items: ferrite balance (specific to each welding process); minimum purity of inert shield and purge gas; testing to ASTM A923 (including for each welder); and an elevated level of in-process QC scrutiny. (I've probably omitted a few others.)
https://www.imoa.info/molybdenum-uses/molybdenum-g...
P.E. Metallurgy
It's still not really apparent where you are going with all of this. It started with A790 and has meandered through A928 and A815. If you are in oil & gas, the upshot is: everything will be heat treated except fabrication and installation welds. The thinking is to achieve as much microstructural uniformity as possible, and optimised corrosion resistance. That's not to say that heat treatment can't be screwed up, and that's why there are detailed, rigorous specifications. Field heat treatment of fabrication welds is totally impractical, and that's why they get a dispensation, but they get the crap tested out of them to prove their acceptability. Here are several more references that you may be interested to peruse:
https://www.iso.org/obp/ui/#iso:std:iso:17781:ed-1...
https://www.iso.org/obp/ui/#iso:std:iso:17782:ed-1...
https://www.onepetro.org/conference-paper/NACE-201...#
Steve Jones
