TEnsion only member and selenderness ratio
7
Is it possible for a tension oly member to fail because of the KL/r ratio ?
RE: TEnsion only member and selenderness ratio
I don't think there is direct relationship. But remotely remember AISC suggests that KL/r for tension member shouldn't less than 300.
A tension member will not fail because of its slenderness ratio but may flap about if the tension is alternately applied and released. An example of this is a cross braced frame where each diagonal member is designed to resist tension only; a change in direction of force on the frame causes a stressed member to be suddenly released while its companion becomes stressed.
BA
I don't think it's going to fail because of the L/r ratio explicitly, but it might fail because a tension member with a very high L/r ratio is going to be quite flexible and prone to vibrating and wobbling, possibly causing fatigue-related issues down the road (at least that's my understanding). I assume this is building-related, but for bridges AREMA and AASHTO both limit L/r for tension members to 200 or 240.
No...a tension element cannot fail in compression
otherwise it would not be a tension element :)
No. Hence, cable elements.
In addition to what BA mentioned, handling is an issue with extremely slender tension members. When L/r exceeds 300 (the suggested limit retired mentioned from AISC), it's more likely that the material will be damaged as it flops around like a wet noodle on the site.
No limit on KL/r for cable members. But, AISC does suggest limiting the KL/r ration for rods, and single angles and such. I haven't looked this up lately. But, if member serves me correct, it's not because of a capacity issue, but that they tend to get easily damaged / kinked. Hence the recommendation (not rule) about KL/r < 300.
Also, I believe some iterations of RISA enforce this recommendation. Though it can be changed in Tools - Preferences / Application Settings.
Thank you all, Really appreciated,
It seems that the member was failing due to the suggested value L/R exceeds 300 in STAAD and it turned to be that I can turn this check off in STAAD.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
