Contact US
Impurity Segregation in Stainless Steel Bar
We are managing weldability risks in orbital welding of small Ø tubing, specifically the effects of sulphur on autogenous orbital welding. For those of you familiar with ASME BPE-97, you will know that this is a base metal sulphur matching exercise. 1" 304LSS bar will be machined at one end to a profile matching a ½" OD x 0.049" wall tube, also 304L.
The question is about sulphur distribution as a function of bar radius: how much variation can we expect from core to OD, and should we be very precise about where we sample for chemical analysis?
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
RE: Impurity Segregation in Stainless Steel Bar
If material was re-melted, no much variation is expected cross bar diameter. At the most there possibly have some variations from the top and bottom of ingot(s) before processed to 1'' bar.
If arc-melted, I expect higher S in the middle of ingot/electrode, especially in those locations with pipes and large porosities.
Can you find bar with the correct S level?
The segregation is going to be a function of both the melting method and the amount of cold reduction.
If this has been heavily cold worked then the variations will be very slight. And you are taking out the center where the most segregation will be.
P.E. Metallurgy
Don't you do the boring of the bar before welding it to a tube? Just out of curiosity, what is the variation you expect from a thickness of 1.2 to 1.6mm? As a user, I know that valve manufacturers maintain higher limit of sulfur content and weld the matching tube spools at their manufacturing unit and claim that as the welding is done in controlled conditions, things are ok and we just accept it.
At 0.03% max sulfur you should not have any welding problems. We do autogenous laser welding on 304L deep drawn thin wall parts by the millions without any problems. Is orbital welding particularly sensitive to sulfur?
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
