Kurtosis miss indication of impacting
Hello Guys,
i have 2 data acquisition with 2 waveform one with impulse and one without.
I made some calculation with my instruments and it is very easy to evaluate impulsiveness of the waveform.
Why, instead, Kurtosis seems have missed this impulsiveness of the waveform?
Let me know about your opinion.
regards
regards
RE: Kurtosis miss indication of impacting
TTFN (ta ta for now)
Cheers
Greg Locock
i'm starting to use kurtosis as "new frontier to find bearing problem" as some salesman use to sell his products.
Some other speak about technique to find impacting or impulsive signal....
I wanted to try personally and i found it is not really as aspected.
Anyway i know some technician use it with good results.
Or i have misconception about how Kurtosis work and the waveform in attach it is a rare case where kurtosis doesn't works or kurtosis is useful for other type of investigation.
I'm not really familiar with statistics and i didn't find yet a simple explanation about how Kurtosis work.
GregLocock
I used crest factor several time but also in this case the crest factor value is not really big. In this case is simple to say crest factor is better indication because you have a comparison signal. In any case i could not to assert impulsiveness only from crest factor because it is very low value.
Cheers
Greg Locock
