Beam-Column joint (Cyclic loading)-Abaqus
[pre]Dear Sir/Madam,
I am investigating the beam-column joint of a building under cyclic loading by using ABAQUS software.
The hysteretic loop of simulation is different from that of experiment as shown in the attached.
It would be great if you could help me to fix the problem.
Many thanks in advance.
Best regards,
Tuan
Best regards,
Tuan
