Welding a welding neck on a blind flange
In a pressure vessel of 75 psig of design pressure there´s a 20" manhole, for the rigth operation of the equipment it needs a vent nozzle on this manhole, usually we made it by welding a 1" threaded coupling to the blind, but due to the rules our custommer is using, they don't allow this kind of fitting, so my idea is to weld a 2" WN flange to the blind, but don't know if it is allowed per codes. I'll appreciate any help. Thanks in advanced.
Julian Barrera
RE: Welding a welding neck on a blind flange
Allowed by codes -> which code? ASME VIII-1?
Regardless if allowed by the code (I think you wont find any section in ASME VIII-1 prohibiting welding a WNRF to BLRF), I wouldnt do it. Whats the extra cost of a small piece of pipe between the WNRF and BLRF, vs all the discussions, questions etc youll get for such an awkward arrangment?
Whats the 20" manhole and blind flange designed to? ASME VIII or ASME B 16.5
Is the hole central?
ASME B 16.5 allows you to tap a hole in the centre up to certain sizes.
Welding one on??
Doesn't talk about that.
I would thread on a piece of pipe then weld your flange if it's a B16.5 blind flange
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
