Valve pressure drop at high viscosities / low temperature
I am designing a hydraulic system that needs to operate as low as -10 C with ISO22 oil. I am trying to estimate pressure drops through valves at this lower temperature.
The datasheets typically show pressure drop vs flow through the valve using an oil with a viscosity of 22-46 cSt. I am wondering how the pressure drop would change if the viscosity increased to roughly 200-300 cSt?
Thanks for the help
RE: Valve pressure drop at high viscosities / low temperature
I am confused
Are going to cool the oil to minus 10 C during cycling?
Usually system warm quick especially when there is a pressure drop...
So do mobile systems working at minus 30 C...
Well pressure drop isn't just the valves, but also the tubing.
It's not easy to extrapoloate viscosity to pressure drop as it's not in proportion, but my guess would be about 3 to 5 times as much pressure drop to go from say 30cP to 300cP.
300cP really is pretty "thick". With smaller diameter tubing this could be a lot more.
Thanks for the replies.
The system needs to be functional with the thicker fluid as it can only be operated for a limited amount of time. We cannot wait for the fluid to warm up and thin out, and it needs to be functional right away at temperatures just below 0 C.
I have already accounted for the pressure drop through tubing, I am just unsure of how to scale it for the valves. For ex, if I have a needle valve that drops 100 psi at 32 cSt, how would the pressure drop change if the viscosity increases to 200-300 cSt. I want to say that it the pressure drop will be pretty similar, as the valve total distance is very small and viscous affects are less prominent on short runs.
But the valve pressure drop is proportional to flow so if the flow is reduced because the frictional resistance in increased in the tubing then it will impact unless the pressure drop int he valves is so much more than the pressure drop in the tubing. It will balance out and my guess is that flow will slowly increase as the temperature increase assuming the pump is putting out the same pressure.
For valves try this https://www.emerson.com/documents/automation/manua... and go to page 3-14
This also might help https://www.womackmachine.com/engineering-toolbox/...
or search "valve pressure drop viscosity correction"
Why not swap it for hydraulic oil of a lower viscosity which is more capable of flowing at the lower temperatures seen?
I have an excel table to do these calculations. But I don't know how to pass it on to you; If you can read:
You must use cell D1, G1, I1, K1 and after column C,D,E. If you have a valve: the flow is turbulent. In this case put a length of pipe of 1mm in column C and enter column D the diameter which gives the pressure drop corresponding to the values ​​given by the manufacturer at the corresponding viscosity.
And if you have a filter or a refrigerant, you must consult the manufacturer's instructions, which often indicate the variations in pressure drop depending on the viscosity.
Good work
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
