state variable in vusdfld
how to define a state variable in vusdfld???
RE: state variable in vusdfld
To define solution-dependent state variable in VUSDFLD subroutine use: stateNew(nblock,nstatev). Here nblock stands for a number of material points to be processed in the call to VUSDFLD while nstatev is a number of user-defined state variables associated with material type. An example can be found in the documentation (User Subroutines Reference Guide --> VUSDLFD). In this example stateNew is used to store the maximum strain as solution-dependent state variable.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - The Evolving Landscape of Commercial Battery-Powered Trucks
What’s driving the evolving landscape of truck electrification? What are the barriers, motivators and strategies for accelerating the electric transition? What insights and resources are available for today’s design engineers working to achieve industry disruption and evolution? For answers to these and other pertinent questions, read this white paper. Download Now
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
