ANSYS 19.2 Combine Force Convergence and Displacement Convergence
pmbov
Hi all,
I am currently running ANSYS Mechanical 19.2. As I run the analysis I want to view both the force convergence solution output and the displacement solution output on the same monitoring graph (Worksheet) so I do not need to click back and forth between them.
Does anyone know how to combine them into one window or even two separate windows but visible at the same time?
Thank you,
Paul
