adding shadows and depth in Abaqus-Visualizing output of a 3D porous material
I am looking to visualize the output of a simulation run on a 3D porous material and do not want it to look flat and homogeneous.
Is there a way I can add shadows to the nodes or use another way to add depth to a material with a lot of holes/porosity.
I am also open to ways to visualizing it in a 3rd software but so far have been unsuccessful in finding a software that can use the .odb file successfully.
All help will be greatly appreciated!
RE: adding shadows and depth in Abaqus-Visualizing output of a 3D porous material
Abaqus/Viewer offers only very basic rendering capabilities (check View --> Light Options). So you will need some external 3D rendering software. Indeed the odb format is not compatible with such programs. However you can convert .fil files to VRML and use it in 3Ds Max for example. For more information check the article "Visualization of ABAQUS Finite Element Analysis Results using 3D-Rendering Software" by Gamperle and Eberlein.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
