Phosphate coating of Hypoid gears of rear axle
My question is regarding phosphate coating of Hypoid gears in Automotive Rear live axle. There are mixed opinion on this, few recommends it while few suggest it as not-necessary. Can anyone suggest in which conditions this coating will be beneficial? and how can one establish its benefit by testing.
RE: Phosphate coating of Hypoid gears of rear axle
testing can be done on a loaded gearset. tests that are used are twofold: the one under high torque low speed, the other one under high speed and lower torque. the first test will give information under high pressure conditions, the second on what happens under excessive sliding (which occurs at the top and bottom end of the gear).
