Hi all,
We are working on a reboiler that is basically of AEU type heat exchanger configuration. The shell side has Glycol while on the tube side there is direct firing through burners. The burner shall be directly firing in the channel side through which the flue gases shall be directed to a tube (one single 14" u tube). The tube shall be immersed in TEG.
We are looking for a suitable tube material to sustain a temperature of 1100 Deg C. Can anyone give any suggestions. I have come across two material by the name of HK-40 and HP-40. However, their temperature range is 900 Deg C max. Although the tube temperature is not expected to go beyond 400 Deg C being immersed in Glycol. But, the small portion of tube that is coming out of tube sheet and into the shell may experience a high temperature. Therefore, we are looking for a suitable tube material that is able to withstand such a high temperature. The temperature of burner flu gases is 1400 Deg C.
Is there any tube material available that is designed to withstand such a high temperature?
