Fox Influence Factor
Geo_Doc
Geotechnical
thread256-411050
The original equation for Fox's influence factor (used for settlement and subgrade modulus computations) is tedious and not easily implemented in a spreadsheet or computer program. I've found this paper that presents a fairly good alternative equation developed using multivariable, non-linear regression on the curves obtained with Fox's equation. [URL unfurl="true"]http://academic.hep.com.cn/fsce/article/0000/2095-2430/FSC-17474-MRK.shtml[/url]
Much easier equation to code and gives results very close to those obtained with the original equation.
Geo Doc, thank you ! this is a very good reference...
