Yeonchan Jung
Hi, all,
I am a newbie in the HYSYS software and desperately in need of a few adcvices.
I am simuating a onshore production facility in Kazakhstan using the HYSYS SW and now a little confused because there is a big difference in the production oil densities which I got from PVT report and simulateion result.
- Degassed oil density from PVT report (20oC, 1 bara) : 849 kg/m3
- Liquid phase density from HYSYS simulation (20oc, 1 bara) : 728 kg/m3
- Molecular weight in PVT report : 215 / Molecular weight in HYSYS : 138.4
I tried other PVT reports from other production field to compare with this error.
The result was around 5% lower densities in HYSYS than in the PVT reports, but not that much as above.
I doubt that there was a mistake while translating the PVT report in Kazakstan language into English.
It seems to me that there are too much light components in the PVT report to make 849 kg/m3 density.
- C6 : 7.4% / C7 - 15.5% / C8 - 16.7% / C9~C15 - 34% / C16~C20 - 10% / Above C20 - less than 1% each
Am I understanding wrong about the HYSYS and PVT report or are there any points that I missing?
One more question, if the PVT report is wrong, is there only one way to correct the mistake, which is to have another PVT analysis? Or, Is there a good way that I can simulate the 849 kg/m3 density and molecular weight of 215, using the HYSYS simulation without the PVT report?
Any piece of advice will be highly welcomed.
Have a good day and happy new year.
YC Jung.
YC Jung.
