Shell & Tube Heat Exchanger Design in HTRI
Phani Y
Chemical
IN
I'm new to Heat Exchangers design in HTRI. Can some one please clarify my doubts below on Shell & Tube Heat Exchangers design in HTRI
1. What all are some key points to be checked after running a simulation in design mode?
2. How do I check which is the governing coefficient from the first design run?
3. How do I confirm that my model is practically perfect?
In case if the information I provided is insufficient, please answer with some assumptions as examples
