Foam Skimmer
NMrbean
CA
We recently had our first case of Foam in our SBRs. We were advised by Sanitare to use a Vac Truck and suck the foam off the SBRs. Has anyone purchased a floating attachment for this purpose?
Maybe you might be better to understand what caused the foaming and try to control it.
Was the foam white and bright and you have low MLSS or is it much darker and greasy looking?
Ashtree
"Any water can be made potable if you filter it through enough money"
What is your DO in your tank and effluent?
