Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
My whole model is one part (not separated parts), Therefore there is no 2 nodes between 2 wires, it's just a common Node (Red node) between them.FEA way said:Actually there’s more than one way to create such hinge joint between beam elements in Abaqus. One method is to add a wire between the nodes, create connector section (join type) and assign it to the wire.
Same before, There is no 2 Nodes, It's one common Node, If there is 2 Node then can you explain more?FEA way said:Another option is to use equation constraint that will couple translations of both nodes.
Same Problem, There is no 2 Nodes, It's one common Node.FEA way said:And finally you could do it with MPC type PIN.
Now If I don't want to divide the frame into 3 parts, Is there any options to separate One common Node (Red Node) To two separate nodes ?FEA way said:To create pinned joint you need two separate nodes for each joint so you would have to divide the frame into 3 separate parts (horizontal beam and 2 columns).
